I have this toposolid which has its elevations and shape done:
But now I need to move the red border by just 20 cm to the "outside". As you can see this area not on the sloped portion of the topo, everything is at 0,00 there:
However, when I edit the sketch, the whole topo gets messed up:
Is there any way to avoid this from happening.
I solved this one by creating an in place void and used it to punch a hole through the topo, but I'd like to avoid using voids if at all possible. Mainly because they're d**n near impossible to find and select later on in the project (or even know they're there), and because coworkers on LT can't do anything with them.
File attached if it can be helpful.
Gelöst! Gehe zur Lösung
Gelöst von azad.Nanva. Gehe zur Lösung
Reset your shape and redraw it.i post a video for you.
@azad.Nanva wrote:Reset your shape and redraw it.i post a video for you.
Thanks for the video!
I know you can redo it all over and that works for very simple terrains like this one (or use voids). I was hoping there's a better way of doing it because sooner or later I'll have to do it on a more involved terrain. I get that elevations change when you edit a sloped terrain, but a completely flat peace of land shouldn't change like this.
don't move them or redraw use Align:
@azad.Nanva wrote:don't move them or redraw use Align
Another Revit quirk to add to the list.
Thank you!
