Hello everyone,
I want to ask if there any method to Modify Scale value to be default value in template such as 1:100, 1:200 , As when i need to change scale to 1:125 I must edit custom and write 1:125 in every view, if i want to change it to be 1:125 i can't chane view scale from view Template, So if there any method to Modify or add this value to be defaulted as 1:50 , 1:100, 1:200..etc.
Start a brand new project from the RTE, add what you want to it and save as template (RTE). Overwrite the old one or name it differently.
You can set the custom scale in your view template to 1:125 by selecting Custom from the top of the dropdown list and then Scale Value will become editable and you can put 125 there.
