Hi, can anybody help with how to make the window head suit the pitch of the roof?
I have spent hrs trying to solve this. The edit profile is no longer available in revit 2024 for Windows; only the edit family tab is available, which does not allow me to change the frame. Can anybody help out in the world?
Please see the attachment to see the window.
Gelöst! Gehe zur Lösung
Gelöst von Alfredo_Medina. Gehe zur Lösung
Gelöst von constantin.stroescu. Gehe zur Lösung
Create a new Window Family with an instance parameter for the angle..as in my attached Family\
Constantin Stroescu
You could make that window with the curtain wall tool, and then use Edit Profile, or Attach to... (select roof or reference plane).
Sidenote: please don't create two threads for the same question.
@steveW29ZU wrote:The edit profile is no longer available in revit 2024 for Windows;
Edit profile was never available for windows. You're probably thinking of curtain walls, and you can still use those to create that window.
Thanks, Alfredo
I will give it a go
Maybe that is the part I missed in the videos
I will go back and review
Cheers Steve
