Editing a dimension style to be able to calculate certain values.
4 ANTWORTEN 4
Nachricht 1 von 5
MVE1112
299 Aufrufe, 4 Antworten
Hello all.
I was wondering if it's possible to edit a dimension style in such a way that i can add a formule in the field under a dimension.
I want it to show the measured distance but also need to show how many bricks and joints are in the measured wall.
I hope this is not really vague. English is not my first language so i dont know how to describe it.
But with brick walls we calcuclate the amount of bricks+perp joints to see if there are no odd sized bricks needed.
See below for what im trying to get..
4 ANTWORTEN 4
Nachricht 2 von 5
MVE1112
als Antwort auf: MVE1112
I believe it is called brick spacing by the way.
Nachricht 3 von 5
RDAOU
Not in the Dimension annotation itself no...Those are text fields you cant add a formula there..
- Either do it in a schedule using calculated values
- Or can use Dynamo to calculate and override the text values or write to sh.param  to tag with
- Or Create a family with Length and/or Height which you can drag and lock to the elevation edges and display that info on the elevations (had something similar for room tiling)
Nachricht 4 von 5
I don't believe that you can do that with a standard dimension, but you can certainly make a line based family that will calculate that and even look like the dimension if you wish.
Nachricht 5 von 5
Create a line based detail family with nested generic annotation labels to show the length and the calculated value.
