Edit visibility settings
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
braicodavid
648 Aufrufe, 2 Antworten
I have a Revit model with a few sections and they aren't showing exactly what I need. How can I edit the default visibility settling when placing a section so I don't have to change each one?
2 ANTWORTEN 2
Nachricht 2 von 3
Corsten.Au
als Antwort auf: braicodavid
Hi
change the settings in Section, usually there's a default view template gets
attached while placing a new section... Get rid of that, or assign a new view template for sections..
untick " New Views are dependent on template "
View Template removal - SectionView Template removal - Section
Corsten
Building Designer
Nachricht 3 von 3
braicodavid
als Antwort auf: Corsten.Au
Thank you.
That did solve my issue
