Edit the Header in a Drawing List
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
jbakaj
2204 Aufrufe, 3 Antworten
I have a drawing list schedule where I have enabled headers to be visible (the grayed out row).  I stumbled across where to edit that text a few weeks ago but have been unable to find where it lives now.  From what I remember it was a formula within a dialog box that read either the "Sheet Sort" or "Sheet Category" fields.  Any help will be appreciated
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: jbakaj
Go to format tab and unhide all fields.
Nachricht 3 von 4
TripleM-Dev.net
Thats not a adjustable field of the Schedule itself
The text comes from the Column next to it "Descipline" or something, in the schedule see the sorting and grouping, and for this field the Header will be turned on.
If you need a custom value here, you need to create an additional parameter attached to the Sheet category (maybe already done?) and set the value per sheet accordingly.
Schedule Field with Header turned onSchedule Field with Header turned on
- Michel
Nachricht 4 von 4
jbakaj
als Antwort auf: TripleM-Dev.net
So after some digging, the field that was created was a calculated parameter.  This allows you to write a formula to have it display whatever you want (Think excel formula).  I needed to then click on edit parameter. This is where I can change the formula to have the header display what I want it to display, not an intuitive process.
