I am trying to create a curtain wall system panel that will adapt to a non rectangular shape. I have created a curtain wall panel with reinforcing that adapts to any rectangular panel, but does not work with non rectangular panels. The system panels adapt nicely however when I add reinforcing Revit no longer treats them as system panels. Is there a solution?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Only system panels can adapt to non rectangular shapes. If you have some odd shapes, consider using nested curtain wall as panel, or pattern base panel off a divided surface, or repetitive adaptive component.
Sorry I cannot give specific solution since I cannot and will not open a docx file off the internet. You should post pictures as JPG or PNG or PDF instead.
Use the first approach I mentioned in the previous reply: Create another curtain wall type with various vertical mullions like what you show in the picture and use it as the panel of the parent curtain wall.
For construction documents, I would just model using a regular panel, and then detail a section view to show the actual condition.
And please don't start the same thread three times.
True that. I wouldn't even detail them in my construction documents. This level of details belongs to shop drawings, which OP is maybe doing.
Would you please give me more information on How to do the following "If you have some odd shapes, consider using nested curtain wall as panel".
Thanks everyone this seems to work. I'll play with it and if anything comes up get back to you.
Hi @Anonymous
Thanks for participating in the community!
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.
Thank you
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
