Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Edit Roof Joists
PhilvK
Edit Roof Joists
PhilvK
I have to adjust the location of my roof joists. It looks like they were placed individually but they are all pinned. Is there a way to unpin them all as a group after I select them, or do I have unpin each individually? Is there a way to tell if they are a beam system?
On a related note, I did enter some floor beams as beam systems and also had to adjust them. I unpinned them (individually) and they moved fine, but the dashed lines of the beam system still show the original layout when the system is selected.
Alan.johnson1970
Select them all and type UP (Un Pin)
or click on the un pin icon (pin with a cross)
if they were placed as a beam system they will highlight when you hover over the edge
AJ.
