Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Edit Roof Joists
1 REPLY 1
PhilvK
418 Views, 1 Reply
Edit Roof Joists
I have to adjust the location of my roof joists. It looks like they were placed individually but they are all pinned. Is there a way to unpin them all as a group after I select them, or do I have unpin each individually? Is there a way to tell if they are a beam system?
On a related note, I did enter some floor beams as beam systems and also had to adjust them. I unpinned them (individually) and they moved fine, but the dashed lines of the beam system still show the original layout when the system is selected.
1 REPLY 1
Alan.johnson1970
in reply to: PhilvK
Select them all and type UP (Un Pin)
or click on the un pin icon (pin with a cross)
if they were placed as a beam system they will highlight when you hover over the edge
AJ.
