Hi. We have a multi level stair, if I setup automatic railing it will be on both the outer and the inner side of the stair, I only need it to be on the inner side but once I deleted the outer it will break the sketch. I don't really understand how to edit the railing sprialing accross mutiple levels, the paths are on top of each other. once edited revit will report error.
What's the best way to edit multi-level stairs? I did some search online looks like no real solution
