Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Edit Profile of Curved Wall
10 REPLIES 10
Message 1 of 11
steve
1876 Views, 10 Replies
Is there a way to "edit profile" of a curved wall?   A work around I guess would be a 3d in place wall family with a void shape cutting it.  https://drive.google.com/a/designbuildllc.com/file/d/1ZkK1_ogomRX2qBk7hNAFZCiB6aCiMImb/view?usp=driv...
10 REPLIES 10
Message 2 of 11
in reply to: steve
I think the only option is an In-Place Void Cut.
Message 3 of 11
steve
in reply to: barthbradley
of a modeled in place family, yes.   Can you do it to a wall, drawn with wall command?
Message 4 of 11
in reply to: steve
Draw a roof by extrusion and attach the wall to it. Then hide the roof.
Message 5 of 11
in reply to: steve
Sure. That's what's shown in screenshot above.
Here's another from inside In-Place editing mode. Draw void and then use Cut Geometry to cut Wall with it. Close out In-Place Edit mode and you've got a re-shaped Wall.
Message 6 of 11
Corsten.Au
in reply to: steve
Hello
Wall profile edit is not available for curved walls.
one way to achieve it is,
Split the wall wherever the angle is changing.
Draw reference lines as per required.
Attached the wall to those reference lines.. ( Just the way we attached walls to levels )
Sample
Corsten
Building Designer
Message 7 of 11
steve
in reply to: Corsten.Au
break walls and then attach to ref line, great tip!    (maybe you mean ref. plane, no sweat, easy to try both)
Next challenge - a way to attach a cap profile to the top.
Message 8 of 11
in reply to: steve
You can create a railing to attach to the top - it just needs a rail with the correct profile.
Message 9 of 11
in reply to: steve
Using the roof method.
Message 10 of 11
zeynepalpgul.01
in reply to: ToanDN
hey can you give me more detail about this roof method
Message 11 of 11
Looks like he just drew a roof by extrusion, attached the wall to the roof, and hid the roof.
