edit profile of a wall by face
4 ANTWORTEN 4
Nachricht 1 von 5
1614 Aufrufe, 4 Antworten
Hello I would like to edit the profile of a wall that has been made by a face of a mass but i can't find any option which alllows me to do this.
4 ANTWORTEN 4
Nachricht 2 von 5
ennujozlagam
als Antwort auf: Anonymous
you can try this. see attached. thanks
Nachricht 3 von 5
als Antwort auf: ennujozlagam
Tanks for the answer, I already knew the functionality of "Show mass" my problem is that the mass is created from a solid made in Dynamo and exported as a SAT file into an in situ mass, and is not giving me the option of editing the profile of the wall by face ive created from the mass.
Nachricht 4 von 5
constantin.stroescu
  • in order to be able to edit a Wall in Mode >Edit Profile , this wall has to be Vertical and not Curved ( in Revit 2021 you can make Slanted Walls but they have no Edit Profile option)
  • the same is true for Wall by Face. If the faces of the Mass are Slanted (not Vertical) or Curved , Edit Profile is not available...Only Vertical ,straight line based Faces can receive Editable Walls
Constantin Stroescu
Nachricht 5 von 5
You cannot. Use a void to cut the mass form before create a wall by face.
