I have edit the profile in the attached wall (picture 1) but the result wasnt successful. It is a wall which axes has an angle. Also in an elevation view the wall has to be edited like in picture 1 ("V" shape)
The result in picture 2 was unccessful because the intersection between tops lines is incorrect. I would like to have an intersection like the red line shows in picture 2. I think the problem is that revit takes the wall like 2 different walls so thats why it gets that interesection because the left wall comes into right wall, inestead of make a division in the vertix.
Do I have a solution for this.
Thankyou.
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
If all else fails, model the Wall In-Place. Looks like you could use the current wall faces as Work Planes in the In-Place Modeling Environment.
Or, maybe try modeling a "deformed" mass and seeing if it will host a Wall by Mass Face.
Wall by ["deformed" Mass] Face:
I would create a roof or two ref planes and attached the walls to it (them). Or, use a void to cut as shown below.
