When I print the sheets of a project in PDF (with adobe pdf) in separate files, the predetermined name is the conbination of *the file name*(in red) + sheet + *sheet name in the project* (in green).
I want to know how can I edit this configuration to remove the "sheet" part, so I dont have to erase it when printing each plan.
Also I want to know if there is a way to print all the sheets at the same time (in separate pdf files), without having to be accepting the printing of each one.
*I add a screenshot of the situation
thank you very much
Gelöst! Gehe zur Lösung
Gelöst von MostafaElashmawy. Gehe zur Lösung
Regarding your first question,there is no current built in method to control the naming methodology. However, you can use a separate app or program to batch rename the files after print , e.g. "ReNamer"
Regarding the second question, follow below screenshot, click Properties of adobe pdf , then instead of "prompt for Adobe PDF file name" browse your printing location and un-check the box beside "View Adobe PDF result".
Mostafa Elashmawy
