Edit line in detail item family
14 ANTWORTEN 14
GELÖST
Nachricht 1 von 15
hliS658H
1729 Aufrufe, 14 Antworten
I want to change the line in this detail item family and make it thicker, but do not see the options?
14 ANTWORTEN 14
Nachricht 2 von 15
msgambelluri
als Antwort auf: hliS658H
There are many ways to  to make those lines thicker, Depending on the situation and its use, One way is in Object Styles or line styles in the Manage Tab Under Additional Settings.
Marcello Sgambelluri
Nachricht 3 von 15
Turn Thin Lines OFF.  :zwinkerndes_Gesicht:
Nachricht 4 von 15
hliS658H
als Antwort auf: barthbradley
in family editor? but where?
Nachricht 5 von 15
Thin Lines is on the Quick Access Toolbar (QAT).
Help | Thin Lines | Autodesk
Nachricht 6 von 15
handjonathan
Hi @hliS658H
Thanks a lot for posting your question to the forums!   Has the solution suggested by @barthbradley @msgambelluri helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
Nachricht 7 von 15
Mike.FORM
If you are wanting a thicker line in addition to the current "detail items" line style, edit the family. Then go to manage --> object styles --> and create a new subcategory and make it whatever you like.
If you are wanting to change the thickness of the "detail items" line style itself you need to do it in the project as @msgambelluri stated.
Once a lines style from a family is loaded into a project then the project settings for that line take precedent. Any change you make to the lines style in the family short of renaming it to create a new style will not override the properties in the project.
Nachricht 8 von 15
hliS658H
als Antwort auf: Mike.FORM
Thanks LOT for your explanations! This is exactly what I was looking for.
The tricky thing is in family editor, you have to go through Manage> Object Styles to add or edit line styles,  instead of  using Manage >Additional Settings > Line Styles as you usually do in project.
In order to find out which governs the appearance of the line from a family, I did a test -
I copied a line style name from the project and created a new subcategory in family editor by pasting the name to be sure they had the same name, but I set it in different color, gave it different thickness - it turned out, the line carried the setting from family,  overrode the setting in project - HOWEVER, a strange thing happened later after I changed the line setting in family and loaded it back to the project, the line didn't change, it still carried the first time setting, nothing same as either the project or the current family setting, not sure what caused that.
Nachricht 9 von 15
hliS658H
" Any change you make to the lines style in the family short of renaming it to create a new style will not override the properties in the project."
I misunderstood you at first , thought you meant line style setting in project governs how the lines from family will look if in case they share the same name. I came to realize that the line style (subcategory under detail item) is nothing to do with the line styles in project.
Line Setting in family that first time loaded into the project decides the appearance of the line in project; If need to change the setting, should create another style with different name in order to see the update. This seems to be a glitch, needs to be fixed.
Nachricht 10 von 15
That isn't the way it should work. Project's Object Styles Subcategory settings RULE no matter.  Definitely something needs fixing.
Post your Family here for testing.
Nachricht 11 von 15
hliS658H
I suspect it is probably the Revit issue. But here is the family I was testing with.
Nachricht 12 von 15
No issue with Revit.  Here's screenshots to prove it:
Nachricht 13 von 15
hliS658H
Yes, as @Mike.FORM stated- "If you are wanting to change the thickness of the "detail items" line style itself you need to do it in the project "
so both your suggestion and msgambelluri  suggestion are to change detail items' line weight, but I have several "detail item" families in the project, I can't directly change the line weight of the detail items in project, I have to do it in family, so @Mike.FORM 's solution is the most appropriate.
The above threads on my test were to respond to his comments on that the updates in family won't work if the family has already been loaded into the project, you have to create another subcategory with different name and assign it to the object and then load the family to the project again, which I think it is a glitch and you may not agree.
Nachricht 14 von 15
All I did was test the family that you posted above. I thought you said it wasn't working properly. I had no issues with it, so obviously there is no "glitch" with Revit.  The "glitch" you are experiencing must be due to something else.
Nachricht 15 von 15
admaecc211151
You could edit the line weight of your subcategories of object styles in project.
Just like the materials, if there is the same name in project and new family.
It will apply the one in project when importing, not the one in your family.
