Edit/delete/add colorscheme CATEGORIES
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
HVAC-Novice
466 Aufrufe, 4 Antworten
How do I edit (delete, add) color scheme categories?
At some point I knew how to do it, but forgot.
and it seems the categories also determine what schedules are available. Each category is a different schedule type.
Can someone explain how that being different type of schedules is useful? I don't use area schedules very much.  but I like a better strategy to use them and possibly schedule areas.
and it seems only in the view template I can select between these categories. If I just select from the view properties, I only get one category to chose from.
Revit version: R2025.4
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: HVAC-Novice
Nachricht 3 von 5
HVAC-Novice
als Antwort auf: barthbradley
No, I want to edit the categories. Like in the screenshot in the OP. Many years ago I created an area category called "CODE STORMWATER".  But I don't remember how I did that and want to delete/edit/add those categories. So I know it is possible, but how?
It appears whatever categories exist also are available to build a schedule (see the second screenshot in OP)
Nachricht 4 von 5
Go the Rooms Areas drop down menu from the ribbon > Areas and Volume computations > Area Schemes > New to add Area scheme.
