Can someone give idea how can I edit shape as attached in image
Thanks in advance
Gelöst! Gehe zur Lösung
Gelöst von BEE_Design. Gehe zur Lösung
Hi vic1z,
This looks like a cranked beam. If you're not doing anything like structural analysis, then you could build your own beam family. Start with a generic model family and create sweep. From my experience cranked beams are scheduled as one element so you can model the whole beam as one generic model. Add parameters where necessary to change dimensions etc.
Good luck!
SY
Hey @Anonymous
Did the above reply from @BEE_Design clear the doubts you had and/or help you sort out the issue of your OP? If yes please mark with "Accept as Solution"
if not, let us know so we may try and find a solution for ur question : o) ... If u solved it already, you might also want to share your solution and close out the thread
