Eccentric foundation wall joining issue
11 ANTWORTEN 11
GELÖST
Nachricht 1 von 12
XXalessio.amodioXX
1887 Aufrufe, 11 Antworten
Hi all
I do have problem in joining properly foundation wall with eccentricity.
If the eccentricity is maximum i cannot join wall foundation.
What is the best way to model it?
11 ANTWORTEN 11
Nachricht 2 von 12
Can you attach your model?
AJ.
Nachricht 3 von 12
als Antwort auf: XXalessio.amodioXX
Trying Unjoining.  Then resize and Join.
Nachricht 4 von 12
You can always grip stretch the foundation farther out and use align tool.
Nachricht 5 von 12
XXalessio.amodioXX
als Antwort auf: ToanDN
Hi
Unfortunatelly this is not working. I enclose the rvt. file
Nachricht 6 von 12
Sure.
Nachricht 7 von 12
Hi all,
Do you have any solutions?
Nachricht 8 von 12
The only way I could get it to look like what i think you want was to change to a Retaining Footing and set the toe to '0'
AJ.
Nachricht 9 von 12
I had no problem with your footing. All you need to do is disallow automatic wall join and join manually (via Join Geometry).
Nachricht 10 von 12
susanaapolayo
als Antwort auf: barthbradley
Thanks @barthbradley
Nachricht 11 von 12
sophiaVETFT
Fixes / Work arounds no longer work in 2020.
Nachricht 12 von 12
XXalessio.amodioXX
als Antwort auf: sophiaVETFT
Hi.
I find out that better solution is to model them as Structural Floor and add a parameter ''Foundation'' in Type Comments or similar in order to better sort and/or schedule them.
