Hello !
My request is a little weird so it would be better if i post on the french forum (but i didn't found it).
My society can't give me admin account easily, so upgrade dynamo is difficult. I need to import a parameter with his Id from Excel. Here in attachment the script but it doesn't works (some pluggin are missing)
Is it possible to import the data without this plugin, or with oldest plugin? I am on v 0.9 ![]()
I thank you a lot for you help !
PS : The export parameter in the attachement works, it is just for information.
Gelöst! Gehe zur Lösung
Gelöst von M_Perez. Gehe zur Lösung
You can replace "ID to Element" with "Select.ByElementID" and you won't need "current document" anymore.
Hello, i tried your node. It belong to archilab plugin and this plugin doesn't works but i have an idea. I will reconstruct the node Under the v0.9.1. It should be okay after that.
I solved the problem by rebuilding the node under the old version. Thank you for your participation. It turns out that the node you are proposing works as you say, but not in my case, I would have to rebuild it too. I will however put you in solution because my problem is solved after your intervention.
Thank you!
