Dynamo simply not using any more roof/floor code blocks if I add any more
Hi there,
Im creating a question code wich is able to make a complete house with only filling in the distances and variables.
Yet everything is working but if I try to add more roof/floor blocks then I already have dynamo will just ignore them and not use them at all.
Is there a maximum of code blocks of one type that you can use or is it something else.
Please help.
Luiscko
I already create something like you want, the first thing is that you need to see like code and the code need steps to follow when you put more that one creation o task that are not related, the case is that Dynamo do not now what thing attend first and there is sometimes that the task don't do any because that, i resolve first doing some script with things that are related and the second i use a lot the passtrouhg node that is from Clockwork 1.x
I let you the demostration that i record for this that i am told you
https://www.youtube.com/watch?v=Jjhm_sYETe0
Luis Rodríguez
BIM Structural | GEDCOM
GEDCOM Institute
YouTube |Facebook |Twitter | LinkedIn
Please look at my other post since I added explaining images there, take not that I didn't had those errors
before I linked dynamo to excell.
Thanks in regards.
