Dynamo Player is greyed out in the Revit 2017.2.3 ribbon. I disabled all addins, uninstalled and reinstalled Dynamo, uninstalled and reinstalled Revit 2017. The Dynamo Player icon is greyed out as soon as I open Revit. Dynamo works fine, it's just the player that isn't working.
Gelöst! Gehe zur Lösung
I found the solution. Revit 2017 doesn't work with Dynamo 2.0.1, so you have to install Dynamo 1.3.3 as well as 2.0.1. When you install 1.3.3, you will be prompted to pick which versions of Revit to install it on, so make sure you just check Revit 2017.
You can find the 1.3.3 install here http://dynamobuilds.com/
Thank You!!! I have been trying to solve this for months and was not able to find a solution! You rock. Thanks for taking the time.
