Dynamo node doors
Dynamo node doors
frozucvcswfqrqahpt
Observer Observer
Dynamo node doors
frozucvcswfqrqahpt
Observer
Observer
Hi good morning to all colleagues.
I'm just starting with dynamo and have a doubt.
I want to know if a door is lefthanded or righthanded. Do you know any node to do that?
rxi.gg
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
frozucvcswfqrqahpt
Observer
Observer
sorry but i cant see that node when i search it
rxi.gg
You have to install the archilab package
frozucvcswfqrqahpt
Observer
Observer
Thanks!!
Keep in mind that for this node to work correctly, your door families must be built with the same lef/right and exterior/interior orientations like the OOTB door family; and there must be a room adjacent to the door in the project.
mary.schmitz-dex
thank you for the help.  Having the pervious discussion visible helped me find the library I needed to install too.
