Dynamo Nod 'Viewsets' is missing in RVT2023
P&L-MEI
Message 1 of 8
P&L-MEI
Hi all,
We've been using Dynamo for some years now, with custom-made scripts. One of the most popular scripts here is the 'plot-by-viewset' where Revit/Dynamo automatically plots an entire set of sheets (to PDF) to the right papersize and saves + renames the files it at a preset location, in the way we like it as a company. Up to RVT 2022, this worked (and stil works) beautifully. However: in RVT 2023 it stopped working. It no longer supports the viewsets ('Unsupported Input Type'). Apparently, it's missing a nod. And that's where the trouble starts: the person who created the scripts no longer works at our company, I've been trying to follow a course on Dynamo but that training has been cancelled twice already. So I don't really know what to do. Yeah I've tried to Google it but there's so much information, I don't know where to start to be honest. Is there anyone who can help me out? Many thanks in advance 🙂
(BTW English isn't my native language so if it doesn't make sense and/or words are misspelled: sorry about that).
Replies (7)
Message 2 of 8
ralphdenhaan
Could you share the script for review? If you are only missing the Viewsets, you can try and download the nodes from Achilab instead.
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
Message 3 of 8
P&L-MEI
Message 4 of 8
P&L-MEI
This is what I'm getting in Dynamo. 'Learn more' doesn't get me anything so I have absolutely no clue what to do...
Message 5 of 8
ralphdenhaan
You can try to create a custom Python node and place this code:
# Import necessary Dynamo libraries
import clr
clr.AddReference('RevitServices')
import RevitServices
from RevitServices.Persistence import DocumentManager
from RevitServices.Transactions import TransactionManager
# Import Revit API
clr.AddReference('RevitAPI')
import Autodesk
from Autodesk.Revit.DB import *
# Get the current Revit document
doc = DocumentManager.Instance.CurrentDBDocument
# Define a function to get all view sets in the project
def get_all_view_sets():
    view_sets = FilteredElementCollector(doc).OfClass(ViewSheetSet).ToElements()
    return view_sets
# Start a transaction to interact with the Revit document
TransactionManager.Instance.EnsureInTransaction(doc)
# Get all view sets in the project
all_view_sets = get_all_view_sets()
# End the transaction
TransactionManager.Instance.TransactionTaskDone()
# Output the result
OUT = all_view_sets
Message 6 of 8
P&L-MEI
Thanks for your reply. Good for you to know: I've never created any Dynamo scripts and/or did any programming. I've made some minor adjustments to our existing scripts. Piece of cake for you probably, huge achievement for me 😉 So the Python node you played is like Chinese to me 😐
Message 7 of 8
ralphdenhaan
The nodes from packages are made with C# or Python. But are not updated very often. So in this case, you can just copy the code I gave you and place it in a Python node. FYI: chatgpt can help a lot:).
Message 8 of 8
P&L-MEI
I'm going to look in it, many thanks in advance 🙂
