Dynamo: Move View Title
dplumb_BWBR
Advisor Advisor
dplumb_BWBR
I've got a Dynamo Definition that aligns Viewports on Sheets, but if the View had already been placed (usually before it's been Cropped), the View Title moves along with the Viewport, and frequently ends up way down off the Sheet in the lower left.
I haven't found any way the move the Title by itslef.
Is there a way to get the Element ID of a View Title and then moves them on the Sheet without moving the Viewport?
L.Maas
I had a look, but I do not think that is possible (yet). Based on THIS thread it appears not to be part of the API (yet). You could head over to the dynamo forum and see what those guys can come up with. As a workaround you might consider removing the view from the sheet and place it again
Louis
Please mention Revit version, especially when uploading Revit files.
Unfortunately it is not possible yet.
You can do some workaround, but no one of them are pretty good in terms of work flow.
