Solved by loboarch. Go to Solution.
Also says Dynamo is for Revit LT in the Revit LT Help
http://help.autodesk.com/view/RVTLT/2016/ENU/?guid=GUID-F45641B0-830B-4FF8-A75C-693846E3513B
The help is incorrect (the knowledgebase articles you linked to pull from the same source). Somehow that page of help did not get flagged to be excluded from the Revit LT help. Sorry for any confusion. We are getting the Help re-published and removing the page about Dynamo.
Autodesk Revit LT softweare developers;
(<sorry>..., answer to "a)" is required for "b)")
a) Do you have forbidden any softweare recomendations ouside Auotodesk`s softweare?
b) Can you help Revit LT softweare users with a workflow to integrate the work done with Dynamo in a Revit LT interfase? ...at any scale or reach...
Please don`t forget to let us, Revit LT users, khow when integration Revit LT + Dynamo is available and the steps nedded to make it possible in our workstations.
Thanks for reading...
@loboarch wrote:
I like your thinking, but alas, I am "Lord and Master" over the help files and can do what I wish (or correct problems at will) but have little influence over Revit LT's ability to have an add-on.
Although in full disclosure, I WAS on the Revit LT design team when the initial decision was made. Sorry 😞
Oh come on, that was funny.
