Could someone correct a dynamo which adding sequential number in the loop of smoke detectors? We will get in label number of loop/ ordinal number of smoke detectors like a S1/1, S1/2, S1/3 etc etc. Unfortunetly, it didn't wotk in my fire systems. Could you change that dynamo that I could use in fire system and I could put the value in that sequence: number of module/ordinal number in fire smoke detector.
I model dynamo the same like on this tutorial: https://www.youtube.com/watch?v=9peUNxoLW3E&t=93s
It should be the same like in this tutorial. I would like to draw the curve and the sequential number be added in fire alarm tag.
Dynamo in attachment
PLEASE it is really important.
