Hello Everyone,
I wonder if there is any Dynamo code for automatically making the views' cadres in the sheets of a Revit file visible?
P.S: before this, I found a code for hiding the project's base point, so I thought there was one for the task above.
Best,
Mahan
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
If you the view's Crop boundaries then you do not need a code...When printing, you can simply check the option to hide them and they will not print
Hello, I'm aware of this option. It's more about the view cadres that I have manually hidden before, and I want to make them visible again, but I don't want to spend time making them visible manually.
Best,
Mahan
Put the following graph together and it should switch them either ON or OFF to your liking
