Dynamo Categories node error
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
BBV90
488 Aufrufe, 3 Antworten
Hello I have a script that transfers my sat. files to revit. I have opened up in my new computer and the categories node gave an error. I remember download
ing a package before. I forgot which one it was and not sure if this is
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: BBV90
If that node is to select a Category then you could try to replace it with an OOTB node.
Nachricht 3 von 4
L.Maas
The node on the right is from the springs package.
I would think the categories node is from the base Dynamo library. It might be that it has changed between versions.
Rmove that Categories node from your workspace and grab a new Categories node from the library and see if that works.
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 4 von 4
BBV90
thank you @ToanDN @L.Maas Dynamo wasnt installed in revit it got solved after
