- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Firstly I take no credit for my progress as I know jack bout Dynamo, so I have credited sources when grouping nodes
Attached find a sample project and dynamo script
**Description of Toposolid**
as you will see thee is a green layer and gray layer(sub surface). Created this using to toposolid then cutting one from the other. Note that what is happening on surface (Green Layer Top) is different what is happening sub-surface (Grey Layer)
I did see mention somewhere that rather then use dynamo just attach the top/bottom of column to the toposolid. Tried this, with it only attaching the top to the underside of the Toposolid
**Objective**
Trying to align to top of the column (centre point, column does not need to cut) with the top of the the green toposolid and have the base align with bottom side of green topo/top of grey topo
it would then modify the top and base offsets accordingly...
Note this was done by eye roughly to indicate objective
Please help with any suggestions and fixes...
