Dynamic blocks in Revit
1 ANTWORT 1
Nachricht 1 von 2
James_Virgo
3034 Aufrufe, 1 Antwort
Hi All,
My company has 4 offices, and our CAD drawing templates use a dynamic block with a drop down menu in the title block allowing you to easily change the office address and contact details depending on which office you are in. I was wondering how I would be able to recreate that in Revit? Without having to produce a set of drawing templates for each office.
1 ANTWORT 1
Nachricht 2 von 2
cbcarch
als Antwort auf: James_Virgo
This is very simple.
Just a Titleblock Family ( .rfa file) which can then be loaded into any Revit Project for all Sheets.
The Titleblock Family will contain a Label that can be edited for address/contact info, etc., images for logo, copyright, dates, etc.
There are literally hundreds ( if not thousands ) of firms using Revit with multiple offices, so you are not re-inventing the wheel here.
Families in Revit are somewhat similar to dynamic blocks in Cad ( only better! )
Good luck.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
