Hi all,
I've a little problem that I can't solve...
I've created an architectural project in Revit 2018 and I've exported from it a dwg and a dxf file of the first floor plant. Than I've tried to open them with my Autocad 2018 but, in the command bar, Autocad tells me that I can't because there are problems with the file (file not valid or incomplete).
If I save the dwg and the dxf file with a previous version (when I export it from Revit) the file works when I try to open it with Autocad.
I don't think that the file is corrupted because it appens with every architectural model that I've used to try and, using the same files the problem there isn't if a save the dxf with a previuos version (not 2018 but 2013 or 2010).
I want to know if this is a known problem or if I'm doing something wrong.
Hope someone could help me...
Many thanks
