DXF export of Revit has no label in IES
Message 1 of 8
I have generated a simple floor layout and added room tags to every space but when i exported as DXF into IES. It says that it does not have any label and i am not able to work on it.
Can anybody give me some ideas on how to solve this.
Esmail
Replies (7)
Message 2 of 8
Tags will export to DWG or DXF as Text, not Attributes.  I am not sure what a "label" is but if you refer to an Attribute then No.
Message 3 of 8
Thanks ToanDN, any suggestion to add text, label or contribute to the room? Is there any way?
Message 4 of 8
I am not familiar with IES so I don't know what a "label" it asks for is.  Can you clarify?
Message 5 of 8
Hello! Did you solve this? I am experiencing the same problem right now as I try to attach my DXF file to ModelIT in IES VE.
Message 6 of 8
Hi, You need to explode the DXF file in AutoCAD first.
Message 7 of 8
brian.muni
Observer
Observer
This is correct! After exploding the room names in the DXF file, the labels were displaying in my IES file.
Thank you!
Message 8 of 8
Durva_Gupta
Community Visitor
Community Visitor
How did you execute explode command?
