DWT File
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
glkirk
1227 Aufrufe, 7 Antworten
DWT File
I need to get a Title block into my program/template.
It seems to be a DWT file.
No matter how I try, I can't seem to insert it into my project.
DWT Trueview will open it but I don' think I can do much from there.
My 2007 Autocad doesn't seem to be able to open it either.
Does anyone have any thoughts?
Thanks!
7 ANTWORTEN 7
Nachricht 2 von 8
a_meteni
als Antwort auf: glkirk
Hi, there's a separate forum for AutoCAD where you can get more help.
Nachricht 3 von 8
hmunsell
i assume you are trying to get the CAD Template (DWT) into Revit? rename the DWT to DWG. you will them be able to link/import the file into Revit
Howard Munsell
Nachricht 4 von 8
glkirk
als Antwort auf: hmunsell
I'm not sure how to rename
I tried the "right click-rename"-added a period and DWG. But that didn't work.
Can you tell me how?
Thanks!
Nachricht 5 von 8
hmunsell
when you rename the file, replace the "DWT"with "DWG" (filename.DWG). if you done see the ".DWT" in the name when you rename it you may need to uncheck the "Hide extensions to known file types" in the File Explorer.
File explorer > File > Options > View > Uncheck, Hide extensions to known file types
Howard Munsell
Nachricht 6 von 8
glkirk
Very kind of you to try to help but I have no idea how to do what you are saying.
This file is on a thumb drive.
The only way I can open it is with the Trueview.
My 2007Autocad LT will not open it. (It will not show up on the screen)
Nachricht 7 von 8
hmunsell
you may want to try reposting your issue here:
https://forums.autodesk.com/t5/autocad-lt/ct-p/2000?_ga=2.120166344.1757118466.1595092306-1640600595...
someone there may be able to better assists you.
Howard Munsell
Nachricht 8 von 8
glkirk
So I pulled it into the computer from the thum drive and was able to do as you suggested and it took care of the problem
Thanks!
