Hi
could you please help me how to open dwg file in revit ...I opened DWG file in Revit but it sees small size in revit also line weight
I hope you reply soon what i need the solution
When you are linking dwg, in a dialog set units of imported file to match units used in that file.
@Anonymous hello, i opened your file and check, the drawing is METER.
1) in autocad - move your drawing > select objects > seleck all > specify base point > pick corner > second point 0,0
2) save
3)open your revit file
4)go to project unit > set to METERS > ok
5) go to insert > link cad
6)select your file > tick current view only > positioning > auto-center to center
7) right click your mouse > zoom to fit.
attached the files for your reference.
