DWG Section Export Appears Misaligned When Inserted Into Another Drawing
dcnkzr
dcnkzr
Hi everyone,
I exported a section view from Revit to DWG format. When I open the exported DWG file by itself in AutoCAD, everything looks perfectly fine — all levels, walls, and stairs are aligned as expected.
However, when I insert or copy this same DWG into another drawing (for example, a composite site or building file), the geometry appears shifted and misaligned.
Has anyone experienced this issue before?
What’s the correct way to export a Revit section DWG so that it maintains its position when inserted into other AutoCAD drawings?
Basam.Yousif
Try on a fresh new file without a template. I think the UCS is rotated.
