Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
we are experiencing problem that dwg sudddenly rotates after closing and opening revit again. Dwg is linked by shared coordinates. We got to remove link, link it again (orientate it to view unchecked) so it gets to the right location. But when we open the file again next day, dwg rotates again..
Any ideas why it happens?
Solved by barthbradley. Go to Solution.
Are you sure your View Orientation hasn't changed instead (e.g. Project North vs True North)?
It could be that in VG the view was changed from project north to true north, but dwg should rotate with it. right? And it is fine as long as you have file opened, the rotation changes after closing and opening the model again
Actual project or true north was not changed.
The project north might have changed on Linked revit model (building file),(but that should not influence the actual model (landscape file), right?
