DWG links and coordinates in revit
8 ANTWORTEN 8
Nachricht 1 von 9
lm4
415 Aufrufe, 8 Antworten
Hi all - my issue is connected to 2 DWGs that I am linking into revit. DWG A links corect in revit by shared coordinates. But DWG B appears somewhere very far awar from my project basepoint. I have tried to see if these is any difference between these dwgs, and there is none in terms of coordinates. I even linked DWG B back into A and all appears in the correct place. My question is what could be wrong with DWG B that it won t link in the same place in revit, even though is links in the correct place in Autocad?
8 ANTWORTEN 8
Nachricht 2 von 9
als Antwort auf: lm4
Perhaps one dwg is georeferenced and the other is not
Nachricht 3 von 9
hmunsell
when you link them in, what settings are you using. Revit likes to set the Imported Units set to "Auto-Detect". I often change that manually to Feet or Inches (or whatever it should be).
Howard Munsell
Nachricht 4 von 9
syman2000
Can you share both of those DWG files so we can see what goes on?
Nachricht 5 von 9
lm4
Hi all, thank you for your replies - i have tried to see if the DWGs are geo referenced or not, and I used the UCSMAN comand - both DWGs have the world coordinates the same.
Nachricht 6 von 9
lm4
als Antwort auf: ToanDN
I have checked, they both have the same world coordinates....
Nachricht 7 von 9
lm4
als Antwort auf: hmunsell
Hi, I use the - By shared coordinates method, in the same units as the dgw - meters
Nachricht 8 von 9
lm4
als Antwort auf: syman2000
i can t really, because of security issues...
Nachricht 9 von 9
syman2000
Check both DWG file and use BASE command. Are both display at 0,0,0? Also Do both DWG have geo reference?
