DWG EXPORT TO CAD POLYLINES
2 ANTWORTEN 2
Nachricht 1 von 3
526996629
277 Aufrufe, 2 Antworten
Does anyone know if there is a way to export certain elements to polylines when exporting dwg?
(I know there is a export rooms, spaces and areas as polylines option, but that's not what I need.)
For instance, I want to export the property lines or some setback lines as polylines.
Currently, I could export them as a block which are not satisfying.
For now, I could only fix them in AutoCAD. I'm wondering if there is better ways. Any suggestions?
Beschriftungen (1)
  • I
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: 526996629
Property Lines?  So you're exporting Plan Views?  If so, what would be the point of a PLine?  Or, are you wanting to  the PLs to show in 3D View?
Nachricht 3 von 3
No there is not.
