DWG export setup color ID for linked parameters
Hi,How can I set different color ID in exporting to DWG setup for link informations?
for example common edge in projection type and cut type are linked but I want to have different color IDs for them.
or for doors the panel line and opening swing ...
thanks
ennujozlagam
you can select  "Export all properties BYLAYER, but do not export overrides." and see if helps. thanks
thanks for your attention but unfortunately it didn't work
i want these two numbers to be diffrent
lucdoucet_msdl
These numbers aren’t supposed to be ”linked” in  Revit. You should be able to click on each one separately and set the number value to the pen width you want.
If this is not the case, could you post the project file to this discussion thread so we can examine it?
-luc
