DWG Export not showing the same Area Scheme Colour
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
jagostinho74
1704 Aufrufe, 5 Antworten
The exported DWG does not match the same Area Colour fill boundaries as shown in Revit.
Any reasons why?
DWG ExportDWG ExportRevit ViewRevit View
Thank you
Assistant BIM/CAD Manager
Manchester, UK
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: jagostinho74
Nachricht 3 von 6
Fill pattern priority is different in Autocad vs Revit.  Try exporting to dwg when Revit is in wireframe....as it looks the wall patterns are taking a higher priority over the area fill during export.
Nachricht 4 von 6
cbcarch
Try setting Color Scheme to Foreground ( or set to background, and see if there is a difference when exporting to Cad.)
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Nachricht 5 von 6
jagostinho74
als Antwort auf: cbcarch
That was exactly it. I should have thought about it. thank you @cbcarch.
After setting it to Foreground there were still some walls masking out the Colour Scheme. This was due to their Cut Pattern being set to Solid. Needed to be set to <none>.
Manchester, UK
Nachricht 6 von 6
Wow! Never expected that solution! Congrats @cbcarch! Personally, I thought @Anonymous had it in the bag. Maybe his was just a great "readers" tip!
Fun Thread all around. Thanks guys.
