DWG - Export Missing lines
0 ANTWORTEN 0
Nachricht 1 von 1
felix.schlenker
188 Aufrufe, 0 Antworten
Hello fellow Revitors,
I've come across a problem for which l coudn't find any solution online. I'm working as medical planer and need to export my drawings/views to DWG for the construction plans. So for every direction of a room (N,E,S,W) there is a view.
In Revit (2019) everything is fine and visible but in the exported DWG are some lines missing (mostly of round/circle objects e.g wheels). To make it even more curious its not always the same. In one view lines are missing, in an other view the lines of the same object are visible/there.
In Screenshot1 you can see the the missing lines / difference between Revit and the exported DWG
In Screenshot 2 the same object is corect exported therefor oter lines are missing.
As I searched for a solution I've come across similar sounding problems so here's what I've  already tried:
All views have the same export values.
I tried to export in different scales up to 1:1 with no luck.
Preserve coincident lines is marked.
I've got no Idea where this is coming from so any help will be apreciated!
0 ANTWORTEN 0
