DWG EXPORT, COLOUR SETTING FOR 'EXPORT BYLAYER & OVERRIDES BYENTITY'
4 ANTWORTEN 4
Nachricht 1 von 5
526996629
230 Aufrufe, 4 Antworten
When I do dwg export by layer and do not export overrides, I can directly set the colors in the color ID as shown below.
However, when I do export by layer and overrides by entity, the colors of the lines in the exported dwg are not affected by the Revit color IDs shown in the image. Does anyone know how to control the colors here?
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: 526996629
Nachricht 3 von 5
526996629
als Antwort auf: barthbradley
Thanks for your reply. That's set. I think there is some overrides on the walls which I didn't find out.
I have attached a revit file and Please use my export setting to export it. You will then see the dwg shown like the image below.
The green wall is correct and the white ones are not showing the colour.
Nachricht 4 von 5
526996629
Hi Barthbradley, I just noticed it's because I got the cut line style ticked which leads to the results above. All good now, thanks!
Nachricht 5 von 5
Okay here.
