Dwg equal Revit
Dwg equal Revit
Message 1 of 16
Dwg equal Revit
Hi everyone, there is a way to export dwg and the colors be the same as in revit?
in my company i can do this just in one computer and the other the dwg get aleatory colors, and i dont know why or where i can configure this
Replies (15)
Message 2 of 16
artejon
Go to R>Export>Options>Export Setups DWG/DXF and under Colors tab pick the 2nd or 3rd option.
Revit add-ins: CAD Purger (delete UNUSED and selected line patterns & line styles, find and delete CAD), Rooms To Spaces, Schedule Utilities (Calculated Values/Combined Parameters To Tags, reuse view filter rules in schedule filters), View Filter Manager at Revit Apps Store
Message 3 of 16
when i use this option all draw be in white
Message 4 of 16
artejon
Are your Revit drawings white on white background ? Could you post screenshots  from Revit and AutoCAD ?
Message 5 of 16
the first image is how i want the dwg draws
the secong image is how the export options be when i load my layers file
Message 6 of 16
and now is how i dont want the dwg files.
I dont know why, but i do always the same steps, but in a computer do like the same as previous mensage, and the computer i use gerate the dwgs like this image
Message 7 of 16
artejon
What are the options checked on both computers under Colors tab ?
Message 8 of 16
The both are the same options, the first
Message 9 of 16
artejon
Pick the 2 nd option to use colors in the Revit view.
Message 10 of 16
To ensure the dwg eport and the Revit sheets look exactly the same you'll need to use the following export settings.
Revit is WYSIWYG, (What you see is what you get), Once you have set up your views and they look exactly how you want them, follow this process.
From the application menu (The big 'R') select export, then dwg.
From the dialog, select the 3 dots next to the drop down for 'Select Export Setup'
Export Layer Options should be set to 'Export all properties BYLAYER, and create new layers for overrides'. This ensures of any elements have manual overrides, filters or other changes in the view to be exported the changes are retained.
We use AIA layers, but it's not important, just pick one that suits you.
On Line tab, pattern tab, text and fonts,  ensure all are set to {Automatically generate ...}
Colors tab needs to be set to Trues colour if you want colours to map the same
Solids Tab, ACIS solids
Units and Coordinates, we use shared basis.
General Tab, we select export rooms option, we hode scope boxes, reference planes and unreferenced tag, but leave 'Preserve coincident lines' unticked to ensure minimise duplicate lines.
Hope this helps
Message 11 of 16
In configuration select COLOR tab, there are two options:
1- TRUE COLOR (you will get exactly what is in your screen)
2- 255 color (configuration according layer color setup)
Choose wisely.
Message 12 of 16
Kimtaurus
Aside from exporting the correct colours, how do you get the right lineweights in AutoCAD?
_____________________________________________________________________________
Please use "Accept as Solution" and give kudos as appropriate to further enhance these forums. Thank you!
Message 13 of 16
hi laura, thanks for the help, but the colors do not respect revit file. In the last case i have exported all layers are black
i dont know why i can not export like this why i told me.
Message 14 of 16
artejon
You could copy your dwg export settings from one project to the other one making troubles using Transfer Project Standards and see if the output is the same.
Message 15 of 16
i can not do this, because the problem is in different computers. one i can export like revit and the other one i can not.
and never works using true colors.
Message 16 of 16
artejon
Can't you send a correct project file to where the other computer is located and try Transfer Project Standards ?
