Duplication when exporting Cast in Place Stair to Navisworks
2 ANTWORTEN 2
Nachricht 1 von 3
921 Aufrufe, 2 Antworten
I am dealing with a project where the client is using the BIM model to take off quantities. The problem is that the stairs are always exported as a whole stair, and as separate run and landing as well. When a cast in place stair is hidden in Navisworks the duplicate shape still exist.
Is there a way not to export the landings and runs as separate duplicated elements?
Attached: NWC file containing the Cast in Place stairs
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
We're having the same issue. We are dealing with it simply with search sets, but it will be great if someone has a solution for just export the stairs but not the runs and landings.
Nachricht 3 von 3
bim.coordination
We were dealing with the same issue, the solution we found was editing the previously Navisworks's settings from Revit to NWC files. All you need to do is change the selection on Model>Performance>On load> Collapse on Convert, from Composite Objects to "None". Then export again your model to NWC file and reload your Navisworks file.
We truly hope this solution does not affect other kinds of families or elements it needs to export as composite objects.
