Duplicating Views and Problem With Duplicating Sections in Plan View
m.milovanovicJM673
Message 1 of 21
m.milovanovicJM673
Hi Revit Community,
I am working on project where I need to use same views on lot of different sheets.
I used the same plan view, multiplied it using "Copy as Dependant" and placed it on numerous sheets.Problem occurs
when I place sections from the same view but also on different sheets... Sections are placed over each other (please see attached)...Does anybody know how to formulate filter to remove all sections but the one that refers to applicable sheet? please note that all section are the same family ,i.e. "joinery section" in this case...thanks!
Replies (20)
Message 21 of 21
m.milovanovicJM673
Hi Toan,
thanks for suggestion but this project is on BIM 360 and 20 people work on it...I am not able to create phases as this may violate office standards...your solution can solve the problem but it isn't quick one... thanks for advice!
