I created an Area Plan for the gross area of a space. I then made a copy of that plan using 'Duplicate View' as opposed to creating a New Area Scheme so that I could subdivide the overall space into smaller area segments. The problem is that when I add more Area Boundary lines, the original plan is changed also. If that's the case, what's the point of being able to Duplicate View? What am I missing here?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Sounds like you are adding onto an existing Scheme when you really want to create a new/different Scheme.
Thank you, I have seen this, but why do you have to use an add-in to duplicate? I would have thought you could do it from within Revit.
I wanted to create a new version (2 below). i.e., expanded view of my gross building scheme (1 below),so that they were under the same heading. I guess in this case, version means 'new scheme'?
as @barthbradley suggests, make new Scheme's as needed. then instead of duplicating, use the View > Plan Views > New Area Plan and select the scheme under the Type option.
if you want to use the same boundaries from another Area view, select them (pick one and select all instances in view) and in the view with the new Scheme, use Past Aligned to Current View. You can modify them as needed.
Howard Munsell
Almost sounds like you are wanting Call-Outs (not new schemes). But whatever; new schemes = new header.
You can duplicate Area plans to add different detailing and annotations but not Area separation lines and Areas. If you want different Areas then you must create another scheme, copy paste aligned Area separation lines and add Areas.
