Hey everyone, so I am trying to modify the parameters of a couple families. I want to keep the current parameters of the family but duplicate it and change the parameters of the duplicate. For instance say I want rigid foam insulation for my foundation wall that is 2" thick and 24" long. There is a family that is 1 1/2" thick and 12" long I believe. When I pull up this family and start editing dimensions it says "constraints are not satisfied". Then when I hit the load into project button at the top right corner and go to place it in my drawing, it says family...already exists would you like to reeplace existing parameters. I don't want to change a family that is preloaded with the program, I want to duplicate it then change it like you can do with a wall type by hitting edit then duplicate then changing thicknesses in the drawing. Any help is appreciated. Thanks
