Hello all,
I have a project in which the core's wall are exposed concrete. In our model we have the model from the structural consultants with these walls.
But we need to have these walls as well in our model so we can add door **** needed. Which is the best practice to coordinate this kind of situation?
In adition, as you can see in the image the structural engineers didn't put the correct door height.
We have the same problem with the slab, but here I know I just can put a floor for the finishes above their model.
Many thanks.
Hi!
you should try Copy/Monitor tool. Here you can find some basics about it.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
DmitriySemko.
Thank for your response. I know the copy/monitor tool, but red it doesn't work very well for walls. I think I have already tried this in the past and didn't work for this particular case.
You are right, the copy/monitor is tricky way, but in case the walls are in linked file., this is, probably, the only way.
