Hi, I have recently come across a problem with colour schemes creating duplicate categories when using transfer categories colour schemes. It seems to happen more consistently with no obvious way of removing or editing the categories from the drop down. Is anybody able to help with this?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
try this
select the duplicated color scheme and reassign it to the original color scheme.
if it is still active in your model it wont let you remove it.
Thanks, how is it possible to re-assign a colour scheme? It is not possible to delete the colour scheme from the list ?
go to a view that is using a color scheme.
edit color scheme
select a different color scheme from the list
if all works well then select the old color scheme and delete it from the list using the RED X at the bottom left of dialogue box
The issue is that categories are duplicating themselves, it is not actually possible to create a category so I am wondering how this is happening and how to delete them. Deleting the last colour scheme still leaves the category behind.
