Ductwork not shown in floor plan
4 ANTWORTEN 4
Nachricht 1 von 5
maritza482LW
378 Aufrufe, 4 Antworten
I am drawing a the structural of a building and then have to add ductwork. I went to the floor plan and tried to add ductwork but I cant see it on the floor plan but can see it on the 3D plan.
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: maritza482LW
Check your Ceiling Plan. Betcha it's there. :zwinkerndes_Gesicht:
Do you see it when you change the View Discipline?  If not, raise your View Range Cut Plane.
Can't see it in the view? Here's 33 reasons maybe why - Revit Forum
Nachricht 3 von 5
maritza482LW
als Antwort auf: barthbradley
It was on the ceiling plan, Thank you! but I need to be able to see it on the Floor Plan, is that possible?
How do I raise the View Range?
Nachricht 4 von 5
It's all about View Range and View Discipline.
Set View Discipline to Coordination.
Increase View Range TOP distance or set to "Unlimited".
About the View Discipline | Revit LT 2018 | Autodesk Knowledge Network
About the View Range | Revit 2019 | Autodesk Knowledge Network
Nachricht 5 von 5
maritza482LW
It worked, Thank you!
